rmulgr
- Jun 11, 2021
- 11
Hey folks. I have a 6 battery bank in my RV with 6 volt interstate flooded lead acid batteries wired in series parallel to make a 12 volt system. Each battery is 225 AH. My converter is failing and I am looking for a replacement converter/battery charger. I am replacing the stock WFCO WF9855 which is a 55 amp, 3 stage converter. I see that I can get up to a 100 amp converter. Are there any advantages to getting a converter with a higher amp output? Would there be any disadvantages? My RV is always hooked up to shore power and the batteries stay fully charged all the time. I calculated all my DC power usage and it looks like the most I would use at one time is around 55-60 amps DC. Thanks for any help you can provide.
