I am installing an Aims 3000 watt inverter/charger in my Rv. Someone said when you put it in...to disconnect and remove the small converter from you Rv. Well I looked at mine which is mounted under my panel box. Seemed simple enough....has 3 wires hot, neutral and ground...and 2 wires to DC side of the panel for powering DC circuits. I turned the breaker off on the AC side going to the converter....and all the power in my RV went off. AC and DC .....is this normal ???
I would have thought only the converter would have shut down and the DC side of the electric panel box. I'm confused why the AC side also went off.....just the same as if I had turned off the Main AC breaker......???????
