ibthalucky12
Greetings,
First time poster here. I am adding a 600W solar array & 560 ah LifePO4 battery bank to a Lance truck camper. I feel pretty confident about the design, with the exception of the inverter. I want to power the existing AC system in the camper, I don't want to do a sub panel.
My plan is to use a normally closed fan relay to turn the DC converter off when the inverter is turned on so as to prevent a power loop by having the converter charging the batteries the inverter is running off of. I have debated installing a manual switch as well or in lieu of the relay for fear I wouldn't know if the relay failed, and the power loop was occuring unbeknownst to me. I would appreciate any thoughts on this.
The big question I have, is if it causes any problem for there to be two power sources to the main breaker panel and potential issues arising from:
A, The prongs on the unplugged shore power plug would presumably be energized if off grid and the inverter has energized the AC system. Is there simply a cap I could keep on the plug when not in use?
B. The inverter hard wire terminals would be energized when shore power is connected. Is this an issue? Is this a known concern and base is covered in how inverters are made to allow this?
I am a beginner, and I realize most everywhere I look, it is advised to create a sub panel rather than energize main breaker panel. However truck campers are small and space is at a premium. I need to simplify and have as few components as possible.
I am also aware that if my intentions of using an inverter are simply not possible or correct I can instead buy a inverter charger with an internal transfer switch and pass through of sufficient amps as to wire the shore power directly to the inverter prior to the main AC panel. This is my second choice due to price, size, and lots of unfavorable reviews of most any converter charger I have seen. I don't want to use victron multiplus due to size and cost.
Thank you in advance for any advice, critique and commentary regarding what I am contemplating.
