EllaBella
- Mar 7, 2020
- 23
If it works for people to use the chassis as a floating ground then that's great, but personally I'd still prefer to have a closed system using pure copper cable. It's safer than if you come into contact with a positive contact point while touching the chassis. On a 48v system you can get a significant shock. On 230v AC you could get a dangerous shock.Ella, i know you wrote previously not to use the chassis for ground purposes due to corrosion issues, but looking at the inverter/charger manual suggests an additional earthing wire from the unit to the chassis. On the SCC, it indicates an earth wire from the negative busbar to the chassis. Ive heard folks talk about an earth wire from the frames of the solar panels to the chassis. There are so many opinions out there all conflicting.
I dont know for sure, which of these diagrams would work best?
View attachment 8925View attachment 8926
I'm guessing people do this to save money on copper cables? It really isn't that much more of an effort to just run a positive and negative.
