I'm looking for some help. I have a Ryobi Zero Turn RY48ZTR100 that is in need of replacement batteries. The easiest solution would be to simply replace the batteries with the generic SLA batteries and most likely have to replace them again next year when they go bad ... again. At an $800 yearly maintenance cost, I figured the better solution would be to outright replace the whole battery system and move to LIFEPO4 batteries. My understanding (which isn't all that much) from another thread here is that I would need to replace the charger, charging system, battery management system (I think that's what BMS stands for), and replace the battery runtime meter since SLA drops in voltage whereby the LIFEPO4's don't.
Any assistance with this would be greatly appreciated. Unfortunately, I'd need a bit of handholding and spelling out as to how to get this working if replacing the SLAs for LIFEPO4 batteries makes the most sense as I've never worked with a BMS and balancing of a battery system before. I'm an IT geek by profession and a certified electrician by hobby, so I can probably figure it out with some help, just don't really know where to start.
