Wondering if I should change the LBCO, and/or some other values?
Situation:
Grid went down about noon.
We switched the house over to solar via the giant transfer switch.
Shut off all the breakers for non-essential loads, so as to prolong battery charge.
Schneider alarm!
I forgot that the water heater timer was configured to run at noon.
Uses 6kw for about an hour to heat up 80 gallons.
(Normally, the PV powers this event.)
Took me a few minutes to realize the situation, and disconnect the water heater,
after which the house load was reduced to the normal 800w vs 6500w.
Anyway, I expected the Schneider system to tolerate 120A battery draw w/o complaint.
Looking for suggestions as to what adjustments I could make to source more amps from the batteries w/o the system freaking out.
Situation:
Schneider alarm!
