Achaffee
Hello, being somewhat of an amateur, I am looking for some feedback on properly setting up my system. It is working but could probably be better. I do have one issue that is when the battery if full the inverter will shut off. My assumption is that it has something to do with settings and the inverter trying to draw too much power from the panels with no where for it to go.
My questions are:
The system is off grid, Growatt 6k Inverter, BigBattery 48v Rhino, 8 – Sun Electronics 205W panels, back up generator tied into the L1 and L2 for “Grid” on inverter.
Inverter settings:
01 utility first
02 90A
03 APL
05 U52
06 restart enable
08 240v
09 60 Hz
11 30A
12 46.0v
13 52.0v
14 solar and utility
15 alarm off
16 backlight on
17 alarm on
19 58.4v
20 55.6v
21 44.0v
22 001
23 dl 5
24 58.4v
25 60
26 10
27 001
28 EnA
Thanks for any input!
My questions are:
- Are my setting correct?
- Can the BMS be used in this setup? I have been unable to figure out which port on the battery the RJ45 cable plugs into. (RS485 or CAN) And what the protocol settings should be on the inverter?
Inverter settings:
01 utility first
02 90A
03 APL
05 U52
06 restart enable
08 240v
09 60 Hz
11 30A
12 46.0v
13 52.0v
15 alarm off
16 backlight on
17 alarm on
19 58.4v
20 55.6v
21 44.0v
22 001
23 dl 5
24 58.4v
25 60
26 10
27 001
28 EnA
