Good point. The neutral doesn't connect to the Garage Panel from either the Grid or the inverter. The drawing does indicate a 120V load on the panel though. Please update the drawing and repost if you need additional help
Done.Good point. The neutral doesn't connect to the Garage Panel from either the Grid or the inverter. The drawing does indicate a 120V load on the panel though. Please update the drawing and repost if you need additional help.
Bentley, isn't a refrigerator and computer insignificant enough to not worry too much about?Actually you should try and balance your 120V loads across BOTH Hot legs & Neutral.
I just want to use it to power a few things in the garage. I'll run it to the house as only backup later. Will my layout work or not in your opinion?Given the fact that the neutral is connected, you can only get 240V out of the inverter.
I would be looking at the feasibility of feeding the inverter with grid and the inverter output to house - falling back to grid as needed.
Ya, only those 2 items on a 10K inverter would be insignificant.Bentley, isn't a refrigerator and computer insignificant enough to not worry too much about?
Ya, only those 2 items on a 10K inverter would be insignificant. I assume you are saying the setup will work?
Guys, Thanks for your feedback. It is appreciated. I will add lights a compressor and maybe my well pump as I ramp up and see what the system will handle. I also intend to feed it back to the house at some point as backup during outages. I may even add a transfer switch at the house to run some circuits. I'm taking baby steps at this point.yes.
Agree, and likely very inefficient.
This 10kW inverter is likely to burn about 120W continuously. That's 2.9kWh/day.
Assuming 2 ton Mr. Cool, that's likely a peak draw of 2000W with no surge. when this is actually running, the penalty for having such a large inverter won't be as large.
Interesting. My compressor motor is only 2hp. I was more concerned about whether it could handle the well pump.I doubt that unit can handle very high surge items. It may claim 6hp motor, but that's really optimistic. While 60lb may sound heavy, a low frequency inverter with a big transformer and legitimate surge capabilities is going to weigh closer to 120lb for the inverter alone - not counting the MPPT.
It's 20,000W surge claim is likely only good for less than 1 second.
I'm not saying it won't work, but you should be cautious when driving electric motors with it.
2hp is probably do-able as it's surge is likely in the vicinity of 10kW max continuous.Interesting. My compressor motor is only 2hp. I was more concerned about whether it could handle the well pump.
