learaviator
- Sep 19, 2021
- 5
I really appreciate input on things. Currently I have 8 280 watt panels, wired in four pairs, each pair in series. The solar panel tag shows 36.75 max power voltage and 7.62 max power current. Currently at max sun I am seeing 60 volts and 32 amps in, and 27.9 volts and 64.5 amps out of my Flexmax 80. I purchased a second Flexmax 80 for a spare. Should I have used the second Flexmax and wired the panels in two groups of four in parallel instead? Am I correct in figuring that with wiring eight panels into two groups of fours, all in parallel I could be seeing approx. 1600 watts from each Flexmax instead of the 1800 watts I am seeing from the one now? Am I figuring this correctly? That seems way better to me. Surely it is not that easy to increase the wattage that much.
