busterbrown
- Jun 29, 2020
- 4
I've installed my first set of 100 watt polycrystalline solar panels on my RV and now am setting up my Victron Smart 100/20 MPPT solar charge controller. I currently have a 300 AH 12 volt AGM battery bank and have installed Victron's BT battery temp sensor.
I need help with the charge controller settings as this is my first solar installation.
Based on advice received from others, I have set the absorption and float voltages to the battery manufacturer recommendations (14.7V and 13.7 respectively). What is the preferred "maximum absorption time"?
I was also told to disable auto equalization of batteries and only perform a manual equalization when the batteries dip below their rated (or expected) capacity. How often would (should) that occur? And, what would be the ideal equalization voltage when the time comes?
Also, is there a recommended temperature compensation value for these AGM's? The disparity is quite big when I look at examples online. The manufacturer doesn't provide this in their specifications.
Finally, tail current setting. I've read 0.5 Amps for every 100 Amp Hours in the battery bank. Is this correct?
Any help is appreciated.
