grizzzman
Photon Vampire
- Sep 21, 2019
- 2,897
Products
Our state-of-the-art portable solar panels provide unstoppable power output even in partial shade. The output of a traditional solar panel drops by as much as 90% when it there's even just a handful of shade!
shadestopper.com
Has anyone played with this tech yet? It seems to me a solid way to reduce the effects of shading in limited room type applications, RV's etc. Where function over cost is more a factor.
Here is a evaluation by a youtuber.
They were unfortunately out of the flexible panels ( they said due to an overwhelming demand for the product ). So I picked up their portable version.
It has 36 schottky diodes to bypass shaded cells, in my opinion series panels of this type would work better than parallel during shading.
I'm headed out on a boondocking trip for 10 days on Friday and will "play" with the unit. Vertical and horizontal shading of cells in line as an example.
I am not a fan of flexible panels, discoloration of the plastic over time, delamination likely due to thermo issues/construction. To at least mitigate the thermo issues if I continue I will conductively connect the aluminum sheet then a greenhouse panel to start with. ( Remember cost is a lower factor here )
Anyone have something to add?
