ianganderton
Auckland, NZ
Good morning
I’m trying to minimise connections in the system I’m installing and have found this
I have a 12v 2000W epever inverter
In the inverter manual it specifies 2 x 125A breakers
Manual - https://www.epever.com/wp-content/uploads/2021/05/IPower-Plus-Manual-EN-V3.1.pdf#page23
The fuse/distribution box takes midi fuses which max out at 200A. Could I parallel 2 x 125A midi fuses with equal length 10 or 16mm2 cables (pretty short, 30cm) going to the inverter?
This solution will radically reduce the number of connections I will need to build which to my mind will radically reduce the number of potential failure/resistance points. Plus the circuits will be dramatically more compact further reducing resistance
SafetyHub 150 Fuse Block - Blue Sea Systems
Ignition-protected fuse blocks capable of consolidating and protecting multiple 1A to 200A circuits.
www.bluesea.com
IPower-Plus Series(220/230VAC) 500~5000W Pure Sine Wave Inverter
IP-Plus is a high-frequency pure sine wave inverter that can convert 12/24/48VDC to 220/230VAC and power the AC loads. Ranging from 500~5000W
www.epever.com
