This is with the Growatt connected to the eg4 LiFePower4 batteries. The GW reports 100soc but where's the voltage cycling?I think they just need some time (2+hrs) to balance while fully charged.
I'd keep absorb voltage at 56.5 but increase your time to 2hrs. You will notice the bms going through cycles of rapid charging and discharging while the cells are balancing. This will only happen when the battery is 100% soc. It took a couple weeks for my batteries to sync up and consistently hit 100% soc.
That being said, i still have nearly 200mv differences in two of my modules after a full charge. Grade a cells huh? Probably not. Hopefully the capacity is as rated.
![1656715151199.png 1656715151199.png](https://diysolarforum.com/data/attachments/100/100917-66dde7319d74fd4df9d543e5fec4f49a.jpg)
![1656715186303.png 1656715186303.png](https://diysolarforum.com/data/attachments/100/100918-2ddad8e63e281cc6903aca7e844858ca.jpg)
