SoCalKevin
- Apr 10, 2022
- 83
Hey All
I recently upgraded my off grid camper to (2) of the 400ah EG4 from Signature Solar (in parallel) and experiencing a weird glitch.
My system:
Victron Multiplus 3000
Victron Cerbo GX
All wired with huge 4/0 cable
Before i swapped batteries (was running ONE 300ah lifeblue), i had zero issues, so i am thinking it is BMS related but not sure.
All my high draw appliances work fine, hot water heater, coffee maker, microwave, etc... I even tried the hot water heater and coffee maker together as a test, and drawing close to 3000 watts, still no issues.
But now, with my air conditioner, when the compressor kicks on, i am getting a low voltage alarm and the inverter is shutting off. All LEDs on the batteries are green, no faults on the batteries, voltage checks fine. The air conditioner draws at max 70amps, much less than the coffee maker and hot water heater.
The air conditioner is the nice Houghton Bel-Aire unit with soft start to prevent the spiking, etc....
This never did this before in almost 2 years of using the old single life blue battery.
Any ideas on what i can start checking? All wiring is even bigger and more robust than required, and i triple checked all connections and they are tight.
I have the BMS software and hooked up the laptop, but its pretty dang cryptic and i am not seeing any issues or alarms
Thanks
My system:
Victron Cerbo GX
Thanks
