tripcode
- Jul 20, 2020
- 12
Hi, this is my first post and likewise, my first solar DIY build I am using this guide as my baseline: https://www.mobile-solarpower.com/simplified-400-watt-fewer-wires-and-alternator-charging.html .
I am currently traveling Australia and just recently purchased a campervan that I am in the process of equipping with the products listed below, based on these calculations:
My solar array:
- 2x250W Mono Solar Panels, rated at 12V / 18.6V (max) and open circuit 22.5V. (https://www.ebay.com.au/itm/12V-250...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649)
- Renogy DC DC Dual Battery charger with an integrated MPPT 50A max current and 25V max voltage ( https://www.ebay.com.au/itm/Renogy-...e=STRK:MEBIDX:IT&_trksid=p2057872.m2749.l2649)
- 2x105 Ah deep cycle batts
- 1000W inverter
- Misc, such as fuses and fuseboxes.
Here are the areas, where I need help:
1. Given the fact that my Renogy SCC is rated at 50A max, with 25V max input, I cannot wire my panels in series, correct? Because, 22.5V x2 > 25V.
2. This leaves me with the option of only running the setup in parallel, which looks like this: 500W/18.6V = 26,88A. Now with optimal charging conditions, i.e. on a super sunny day, I would waste 1.88 A if I am driving around. Because during dual-battery-charge-mode the Renogy will split the max current to 25A/25A. Is this correct...? I mean, since it is only 1.88 A I think its not too bad. But question here is, shouldnt the SCC always be sized to have a little extra room, i.e. my setup will most likely run on its 'maximum potential' a lot from what it seems.. will this do any 'harm'?
3. Pretty much a follow up question to 2., what happens to the excess 1.88A ...I assume it will just not be 'drawn' by the Renogy module and thus it sits in the form of 'unused energy' on the solar panels? This will not cause any troubles I assume.
4. I double checked with my mechanic, my cars alternator is rated at 90A. Thinking again about this 25/25A mode that I am facing when driving around. Isnt it a big waste to have all the Amps from my alternator 'throttled' at 25A? I could help this situation out a bit, by installing a circuit breaker on the solar panels positive I suppose and switching it off manually, if I am driving around on a cloudy day to avoid a situation where I would get 25A from the alternator and 5A from PV. Thus, allowing me a 50A max from the alternator, however.. its still nowhere near what my alternator can output maximum, which is 90A! Did I just make a big mistake by deciding for the Renogy Dual Battery Charger?
5. My understanding, when going a bit more in-depth with question 4, is that the Alternator will charge my starter batt, once that reaches a certain voltage threshold, the Renogy adapter will relay the Alternator current to my house batts. Or auxillary batts. Now, am I too optimistic by thinking the alternator would actually output 90A ... ? Is the output frmo the alternator in reality much lower, because it is still tied up to the starter batt, regardless if it is full or not?
6. What are the weak-points/flaws in this setup besides the topics I have addressed in my questions above?
7. Assuming I am right and 4. and 5. seem to be bottlenecks: Would it help if I had a SCC dedicated for my solar setup and use an isolated VSR that is rated to handle 90A to charge my house batts. I.e. send my Renogy module back and do everything seperately by using a dedicated MPPT and VSR?
My solar array:
- 1000W inverter
