mbesto
Total newb to solar here, so I'm trying to start simple. Hopefully down the line, I'll build my own systems.
I have a vacation rental property in Costa Rica and often the power will just go out randomly so I'm looking to build a simple, but mostly off the shelf, backup solar system to provide internet even if the rest of the power goes off. This is so I can sell to digital nomads. Here is my internet setup:
Specs on the battery and panels
Questions/confirmations:
- Netgear = 110W max (I have 8 PoE access points connected, so this indeed might hit this amount...either way, just looking at worse case)
- Starlink = 75W max
- Cable modem = 24W max
- Total = 209 W
Quantity | Description | Link | Price |
1 | EcoFlow DELTA mini Portable Power Station | https://us.ecoflow.com/collections/...portable-power-station?variant=39976376434761 | $549 |
3 | HQST 100 Watt 12V Monocrystalline Solar Panel | https://a.co/d/5E9qiN3 | $221.97 |
1 | iHaospace XT60 Adapter to Solar Connector Cable 12AWG 25FT | https://a.co/d/hUVGyOY | $39.99 |
1 | Solar cables extensions | https://a.co/d/aYoMeG9 | $75 |
TOTAL | $810.96 |
- Ecoflow solar:
- 300W 11–75V DC 10A max
- Pure Sine Wave, 1400W total (surge 2100W), 120V~ (50Hz/60Hz)
- HQST 100 Watt 12V Panel
- Optimum Operating Voltage (Vmp): 18.0 V
- Open-Circuit Voltage (Voc): 21.6V
- Optimum Operating Current (Imp): 5.56 A
- Short-Circuit Current (Isc): 6.5A
- Am I thinking about the power input/output correctly and what the Ecoflow can handle?
- Is series (not parallel) the way to go to ensure I stay within the range of the Ecoflow rating? (shade not an issue)
- Does it make sense to do 1x 100W solar panel and 1x 200W solar panel instead? (my roof can support this)
- I would simply plug the Ecoflow into AC wall power for charging and plug the internet devices into the Ecoflow so that way there is zero interruption to the internet, even if the power goes out. I assume the Ecoflow has config to flip over to solar if its available and no AC wall charging is available, right?
- Is there a better / more efficient setup than this for the price? note - I've thought about just doing my own batteries/controller, but
