A common enough question. But with panels coming down in price, and the additional cost of putting a few more up when installers already on site being low, I want to get it right. Have already upped initial panel number and need to know where to stop!!
Per day:
House usage 29kWh (about 90th centile real usage) but quite consistent usage
Probable hot tub - 5 kWh
Probable ASHP - 12 kWh
Allowable grid export 7kW
Economy 7 aga (possible dump load) - 32kWh runs at cheap rate
Peak loads for house 4kW without hot tub or ashp.
We do not yet have hit tub or ashp but both likely in near future once solar done - consumption is estimate.
Battery will be 15.5kWh
Do people size for the sunny 5-6 months?
Assume aga runs on E7 from grid, and export is 0 - ie treat putting into both as a bonus - then need is 46kwh. Probably lower as well move washing/drying to when solar production highest etc.
40 420w panels 16.8kW (10 on garage, 30 on roof) gives 40kwh/day for about 7 months according to pvgis, 54-70 for peak 4-5months. Shropshire, uk, with Octopus.
Is this oversized? Undersized? About right? I can put a few more panels on the roof if needed, or fewer. Planning on paralleling 2 solis inverters either 5.5kw or 8 just need to check over panelling specs.
All input welcome.
Thanks!
Per day:
All input welcome.
Thanks!
