Steve_S
Offgrid Cabineer, N.E. Ontario, Canada
Excellent Find / Link.Better than Braided busbars?
Eriflex Flexibar has insulated plastic on the outside and tinned copper on the inside. This comes from the factory on UL starters and drives of over 1000 amps. Normally installed between the starter and the motor.
Measure it up and cut to size. Drill a hole in it through the bars. Cut the plastic back to expose the conductor. No need to add wire connectors or shrink wrap on the ends. A slight bow from terminal to terminal will allow for expansion if needed.
There are different sizes and amperage up to 2000 amps, the link below is listed for 400 amps. The size in the link is Width: 0.79 Inches Height: 0.24 Inches Length: 78.74 Inches.
View attachment 23892View attachment 23893Galco
www.galco.com
I just ordered four https://www.galco.com/buy/ERICO/534507 to use between my Chargery DCC's and Shunts, this looks like the perfect solution to a the conundrum I was having, I was not happily entertaining the idea of making up really short 4/0 "Dog Bones" with cable & lugs.
