Hello, I'm working on my solar system and had a different thread going with some other questions. Here is the link for reference https://diysolarforum.com/threads/new-van-system-planning-help.13073
My question for this thread has to specifically do with looking for suggestions for a high quality (or maybe even medium quality) combiner box that is on the smaller side. This is going inside of a van so space is very tight and I'm hoping for something on the order of 7"x"6"x4" or smaller. I have 3 panels on the van in parallel and need to fuse each panel and then would like a breaker/disconnect. I'm trying to limit the MC4 connections since it seems like from reading different threads the quality is very inconsistent and only Staubli are high quality. So I was gonna do a single MC4 connection at the panels themselves and run that inside the van and then bring them into a combiner box. The only small combiner box I've found so far of any name brand is this Ecoworthy one https://www.eco-worthy.com/collecti...circuit-breakers-for-on-off-grid-solar-system
From reading other threads it seems like Ecoworthy is kind of at the lowest end quality wise, only being above all the generic cheapo versions all over Amazon. So I'm a bit hesitant to use it and would prefer to find a slightly higher quality one of similar dimensions. I looked at Midnight Solar, Watts247, Renogy, and didn't find anything as small. Does anyone have any other suggestions or brands they'd recommend I look further into?
Thanks
Thanks
