Victron smart solar controller switch is default to position 2 for battery configuration.
I have gc2 deep cycle and not sure what position is best.
herer is the page from the book
3.5 Configuration of the controller
Fully programmable charge algorithm (see the software page on our website) and eight preprogrammed charge algorithms, selectable with a rotary switch:
Pos
0 1
2
3
4 5 6 7
Suggested battery type
Absorption Float Equalize dV/dT V V V mV/°C
@%Inom
Gel Victron long life (OPzV) 31,8
Gel exide A600 (OPzV) Gel MK
28,2 27,6 @8% -32
Gel Victron deep discharge Gel Exide A200
AGM Victron deep discharge Stationary tubular plate (OPzS)
28,6
27,6
32,2 @8%
-32
Default setting
28,8
27,6
32,4 @8%
-32
AGM spiral cell Stationary tubular plate (OPzS)
Rolls AGM
29,4
27,6
33,0 @8%
-32
PzS tubular plate traction batteries or
OPzS batteries
29,8
27,6
33,4 @25%
-32
OPzS batteries
30,2
27,6
33,8 @25%
-32
OPzS batteries
30,6
27,6
34,2 @25%
-32
Lithium Iron Phosphate
28,4 27,0 n.a.
0
(LiFePo4) batteries
Note 1: divide all values by two in case of a 12V system.
Note 2: equalize normally off, see sect. 3.8.1 to activate
(do not equalize VRLA Gel and AGM batteries)
Note 3: any setting change performed with Bluetooth or via VE.Direct will override the rotary switch setting. Turning the rotary switch will override priori
Pos
0 1
2
3
4 5 6 7
@%Inom
28,2 27,6 @8% -32
28,6
27,6
32,2 @8%
-32
Default setting
28,8
27,6
32,4 @8%
-32
Rolls AGM
29,4
27,6
33,0 @8%
-32
OPzS batteries
29,8
27,6
33,4 @25%
-32
OPzS batteries
30,2
27,6
33,8 @25%
-32
OPzS batteries
30,6
27,6
34,2 @25%
-32
28,4 27,0 n.a.
0
(LiFePo4) batteries
