I am having an issue when I'm charging my EV @ 40a my inverter is set to only use the grid during the time that I charge (off peak) but it seems to be pulling 10k from the grid and 2k from the battery no matter what. If I set the car to charge at 32 amps instead of 40a then it only pulls about 700w from the battery the rest from the grid. From my understanding in the time of use set up if you have the battery set to 100%, it should ignore it.
My setup is two sol-ark 12ks in parallel. 2 EG4 Power Pro batteries 14000w solar 6 DC strings and 1 string 2000w solar micro inverter AC coupled.
