Traviss224
- Jun 25, 2022
- 322
In series amps stay the same 8 and volts multiply 240vI have never understood the amp, volts etc in series.
So I should have 8x30=240v, 8x8amps=64?, and wattage 250x8=2000?
You got the wattage right.Thanks what about the wattage?
yes, a loose connection will cause the voltage to complete the circuit by jumping (arcing) the gap.Tim if was a loose connection, it wouldn't read at all? Or would it?
