Solar and Battery Well Constant Flow - Sanity Check
cjl
I have a 200' well estimated at 12GPM. I am using this to maintain/fill my stock tank. I started out with down the path of full solar running 4 panels to get to above the optimum run voltage, but have started thinking to run 24/7 to take full advantage of the resource. I don’t know what the replenishment rate for my well will be, but I am planning to install a timeclock and will set it to run a duration of X minutes to deplete the well and then have it run every Y minutes/hours based on the replenishment rate. This is to keep the pump from cycling to often.
Does my attached plan look like it will work? What do I need to change?
