I’m not sure what exactly is being measured as “charged” and “discharged” for the LV6548. Is it DC? AC? I had assumed it was DC but other values reported are grid power, load, etc, which are all AC. If it’s AC, I’d expect an AC->DC conversion loss, loss due to resistance on the DC side of the wiring, then losses due to battery internal resistance as the pack voltage increases. Discharging would have similar losses due to DC wiring resistance, conversion to AC, etc.
You can configure the idle consumption of your inverters but even accounting for that, I just have to chalk up the losses to inefficiencies. Many people have suggested getting a shunt but that’s not going to help you on the AC->DC side or DC->AC side.
I’ve run some recent tests in which I’m running in utility/battery priority mode so batteries will only kick in if grid power is lost. For the MTD, I have a total of 300 kWh of load yet grid is reporting 403 kWh. The difference seems excessive for inverter consumption for essentially running in bypass mode 99% of the time so I’m somewhat at a loss.
