elizabethii
- Jun 3, 2022
- 25
I've had 4 EG4 3kw inverters and 6 EG4 lifepower batteries connected to Solar Assistant now for several months. SA's running on a Pi 3 It's been working great, except for the past 2-3 months. After being up for around a month, the web interface starts getting really laggy, then grafana graphs stop loading, then the web server eventually stops responding at all. Power-cycle the Pi, and all is great again for another month, except that all historical data is gone. Also, I signed up for the beta program, and after the upgrade, it's on the new version, except that once I power-cycle, it fails back to an older version of SA. I'm suspecting that something related to the storage is failing, like the SD card.
So, I have a Pi 4 that has been sitting around from a previous project, so I thought I'd load up SA onto a fresh card in it. I opted into the beta program before starting to configure the batteries and inverter. So far, so good. However, about a minute after the batteries are connected and SA gets what appears to be a single update of the battery info, it'll lose connection to the batteries and not reconnect until I go into configuration and disconnect and reconnect. I have automations that rely on battery SoC, so that's not good.
On the Pi 3, I had the SS-supplied RS485 converter plugged into a USB hub. Thinking it was something related to that, I plugged it directly into the Pi without any changes in operation. The Pi 4 is being powered by the USB adapter supplied in the Canakit I bought the Pi4 in. I'm at a loss as to what the issue is. I even looked at journalctl to see if there's a buried log event with more information, but if it is, I can't find it. It goes from "[bms:narada] [connected] Connected" to "[bms:narada] [error] No response. Retrying..." with nothing about the USB device mentioned in between.
Any thoughts on what the issue could be?
