FilterGuy
Solar Engineering Consultant - EG4 and Consumers
I have a couple questions about the Victron smart solar 75/xx and 150/xx charge controllers.
Background:
I am thinking about using one of these on a 24 volt Nano-hydro system instead of a diversion controller. I would like to do this for a few reasons:
a) Just like solar, hydro has a max power point. Using the MPPT function to find it would be nice.
b) The diversion controllers that give you reasonable configuration for the charge profiles are very expensive.
c) I really don't trust the voltage control you get by putting a diversion load controller in parallel with the battery.
Questions:
1) The 75/xx and 150/xx charge controllers are for strings with voltage up to 75 and 150 volts respectively. Is there a higher 'max' voltage that they can handle on the input? (I assume it clips between the 75 or 150 and the max) Since these are not diversion controllers, the turbine voltage can go high if the batteries are full and the power is not used. I need to make sure the peak voltage from the turbine wont damage the charge controller.
2) Are the controllers sensitive to ripple on the input? The turbine outputs DC that is rectified from 3 phase AC. Naturally this will have some ripple and I need to know if this is a potential issue. If I have to, I could deal with this using large capacitors and maybe even a reactor to smooth the ripples, but I would prefer not to add anything I don't need.
Background:
Questions:
