Hi Folks,
I have a decent sized solar setup with DIY LiFePO4 and understand the basics however I'm struggling with a few concepts I've seen within the wind/micro hydro generation space and was hoping someone could clear up my understandings/confusion.
The installations I've seen online, tend to be exactly the same as solar, the only difference being the choice of charge controller often being Midnite. The specific part where my understanding of the logic breaks down is dump loads and the requirements for them over a few other options that I would've guessed if i hadnt researched a bit.
I understand dump loads are needed to prevent overcharging of batteries in the event there's excess power within the system.
However in solar when batteries hit absorption phase, charge controllers keep voltage static and amps will decrease over time, preventing overcharging of the batteries.
For hydro/wind I understand in absorption phase to prevent overcharging a dump loads is used and controlled via PWM controller to turn load on and off.
And this is needed because the MPPT keeping voltage static not reduce the amps in a turbine system like it does with PV as PV will not produce power unless there's load? Am I correct in my understanding so far?
If so my questions are why is dump load used over these options.
1. Instead of a dump loads you still use a PWM but rather than turning on/off a dump load repeatedly it instead shorts the 2 of the wires coming out of the PMA acting as a break for the turbine but only temporarily. The only reason I can see this being worse than a dump load is maybe the breaking is too aggressive when compared to just introducing load to the system ie the break slow it too much vs just adding a load via PWM? Or is there another reason why this isn't used?
2. (Hydro only) Use PWM to just disconnect battery or turbine from the system altogether, assuming turbine can safely free at max speed (given you know pipe size/max water through pipe you know max power, I understand with wind this isn't an option as free spin would not be safe).
I unfortunately dont have the money for land that is able to use micro-hydro or wind but maybe oneday but just like to wrap my head around the logic of it all.
