L lns New Member Joined Nov 2, 2021 Messages 67 Dec 15, 2022 #1 Has anyone put in a solar dc pool pump w/o battery in parallel with AC pump and can share some knowledge and experience?
S ShanePowerHouse New Member Joined Dec 14, 2022 Messages 29 Dec 15, 2022 #2 lns said: Has anyone put in a solar dc pool pump w/o battery in parallel with AC pump and can share some knowledge and experience? Click to expand... I wouldn't add the extra complication. This is what I plan on using next summer for mine from Signature Solar check it out. Growatt 2.2kW 3HP Solar Pump Inverter l Water Pump Inverter | Grid-Assisted | SPI 2200TL2-HV
L lns New Member Joined Nov 2, 2021 Messages 67 Dec 24, 2022 #3 ShanePowerHouse said: I wouldn't add the extra complication. This is what I plan on using next summer for mine from Signature Solar check it out. Growatt 2.2kW 3HP Solar Pump Inverter l Water Pump Inverter | Grid-Assisted | SPI 2200TL2-HV Click to expand... I'm trying to set it up to avoid freeze issues without having to hook batteries or an ac to dc converter.
