Hi - I have 30 ground mounted Bluesun BSM460M-72HBD that will feed an EG4 18kpv inverter. Specs of panels are below. This will be inspected, but trying to do leg work for electrician- my time is cheaper than his.
I have two questions:
1) I plan to do 3 strings of 10 in serial. Do you see a better way to arrange these? I may add another 10 panels at some time and use the combiner in MPPT #1.
2) How should this be wired that the mounts? A non-fusible or fusible switch the the whole thing then breakers for each series? If you could point to specific products, it would be helpful.
Thanks,
Greg
Thanks,
Greg
