ericfx1984
- Oct 10, 2021
- 741
I am planning a big off grid system... I'm trying to figure out the best way to configure the panels I have with the solar charge controllers that I have.. I will be running a 16s, 304ah lifepo4 battery with 200a BMS
Be running two solar charge controllers
-Inverter AIO MPP LVX6048 (up to 450v PV input & upto 120 amp charging)
-EPEver Tracer 6415AN (upto 150v PV input and upto 60a charging)
I currently own 41 Santan Solar T Series 250w panels
Specifications:
Rated Power: 250W
Open circuit voltage (VOC): 37.6 V
Max power voltage (VMP): 30.3 V
Short circuit current (ISC): 8.85 A
Max power current: 8.27 A
Power Tolerance 0/+3%
Maximum system voltage: 600V (UL)
Fuse Rating: 15 A
Specifications:
Rated Power: 250W
Fuse Rating: 15 A
