1. Some grounding lugs don’t have the “teeth” to bite into the frame. I understand you can scuff the frame to remove the anodized coating. How much scuffing are we talking?
2. My array is connected to an IMO dc connect switch, there are no dc breakers. Does this mean grounding is pointless? I.e there is no breaker to trip if current is on the panels, or frames. Should I also add a dc breaker to the array circuit in addition to,the,disconnect switch?
