Good day everyone,
I recently moved in Africa and due to issues/outages of electricity I decided I really need to go solar![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
I am new to solar but I have general knowledge in electricity so everything i'm saying it's base on my research![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
After doing some research I found out that actually the solar panel power output is given by a formula which is multiplied by solar irradiance. From what I know, in most areas, temperate ones, solar irradiance is 1KW/m2 standard but after doing some digging on this, I found out that here, solar irradiance is between 3,8KW/m2 and 4.6KW/m2 during the year which would impact my solar sizing because I would need to multiply with the solar irradiance and some power loss because of the heat i suppose..15-20% ?
I need to clarify this in order to get the right amount of panels for the 15KW inverter I want to get..so optimal solar panel output should be between 19.5KW and 22.5 KW
So, from my calculations, the optimal number of 550w mono panels would be 14 calculated like this: (14 x 550w x 3.5[irradiance]x80[heat loss])/100 equals ~21.5 KW
Also, need to take into consideration that one 550w panel is larger than 1m2 and I used a lower irradiance than the real ones given by the statistical data so the output should be bigger than 21.5W...
Are this assumption correct ?
Thank you!
Thank you!
