Mono Perc vs Monocrystalline - Canadian Solar Panels
Solar_Duc
I'm deciding between two panels for my project, I already have approved building permits and PG&E interconnection agreement (need to be careful about what I change). I submitted the Canadian Solar CS3N-390MS, however it looks like pricing is much better on the Canadian Solar CSR-390MS. I'm going to be installing 28 panels and the CS3N panels are about $40 more per panel so it adds up, is it worth it?
CS3N-390MS (390W)CS6R-390MS-HL (390W)
DC Electrical Characteristics
STC Power Rating390W390W
PTC Power Rating367.93W1367W2
STC Power per unit of area17.8W/ft2 (191.8W/m2)18.6W/ft2 (199.7W/m2)
Peak Efficiency
19.18%​
19.97%​
Power Tolerances0%/+3%data not available
Number of Cells
132​
108​
Nominal Voltagenot applicablenot applicable
Imp10.6A12.84A
Vmp36.8V30.4V
Isc11.38A13.7A
Voc44.1V36.4V
NOCT42°Cdata not available
Temp. Coefficient of Isc0.05%/K0.05%/K
Temp. Coefficient of Power-0.34%/K-0.34%/K
Temp. Coefficient of Voltage-0.115V/K-0.094V/K
Series Fuse Rating20A25A
Maximum System Voltage1000V1000V
Mechanical Characteristics
TypeMono PERCMonocrystalline Silicon
Output Terminal TypeMulticontact Connector Type 4Multicontact Connector Type 4
Output Cable Wire Gauge12 AWG12 AWG
Output Cable Wire TypePV WirePV Wire
Output Cable Wire Length1,250mm (49.2in)
Frame ColorBlackBlack
Backsheet ColorBlackBlack
Length1,940mm (76.4in)1,722mm (67.8in)
Width1,048mm (41.3in)1,134mm (44.6in)
Depth35mm (1.4in)35mm (1.4in)
well at 40$ per panel. 28 panels x 40$ is 1120 dollars. Enough for you to get more panels if you have the space for it.
I like that the csr has less cells. I also like the efficiency of the csr. 18.6w/sqft.
They otherwise seem to be similarly rated.
How does the lower voltage of the CSR impact the layout and string voltages. Will you need larger conductors?
I was playing around with the layout last night and the CSR actually works better allowing me to fit 2 more panels. The deal I'm looking at is for a pallet of 30 and I was originally looking at a 28 panel layout. So I would have the panels to add the extra 2, given that it seems like the way to go is with the CS6R + $1,120 savings in panel costs.
What price are you getting on these solar panels as I need to buy a pallet also, are they the ones on signature solar?
