frankz66
Hello everyone, I have 4 panels of 180 watts 12v PERC 9.43 amps
These panels are configured in 2s2p . I noticed on one of the panels that one square of the panel with respect to the others is slightly blue unlike the others.
This imperceptible and not obvious difference has raised doubts if it works perfectly or there may be problems. I checked the no-load voltages of all the panels and they turn out to be perfect as per the label. in the configuration I performed without bypass diodes as there are no partial shadows, I connected the first two panels in series then a negative and positive output, same configuration on two others and to finish with a Y adapter connected the 2 positive and hard negatives to have 43 volt
Thanks to everyone for any info
