JLMAC
Hi everyone,
I'm putting together a 48V system, using the EG4 48V LifePower 4 rack battery and the Growatt 3kW Stackable off-grid Inverter SPF 3000TL LVM-48P for a small RV. I need advice picking two 400w panels that would be compatible with the SPF 3000TL LVM-48P Inverter. I'm going with this inverter because it has a lower voltage solar panel demand (VoC?) than the EG4 3000kW Hybrid Inverter. I don't have much surface area to mount the panels; that is why I'm going with the two 400w panels. Can any of you please point me in the right direction with the solar panels and recommend a brand with the panel model? Thanks.
