anonlakr
Hi forum,
Right now I have 5 x 120 watt solar panels connected in serial.
I previously had a Ecoflow Delta Pro Max that I would connect the panels to and then use the AC output for the UPS in the homelab.
I sold the Ecoflow Delta Pro Max - mostly because I was tired of wheeling it around and because I wanted something rack mounted.
Now I would love to be able to have the solar panels charge up the UPS and when the sun is not out (or night) it will charge with AC from the wall/grid.
I guess I have to options:
1 - get a solar inverter that will have an AC output and then get a load balancer that can accept 2 sources (solar panels and AC), there must be a degree of programming so I can make it prioritize the solar input somehow. This loadbalancer will then charge the UPS.
2 - Get a rack mounted battery (5KW capacity) and a solar charge controller, a solar charge controller (also with dual input) to connect the solar panels to, finally an inverter that will charge the new battery - then sell the current UPS and use the new battery as a UPS.
Is this even possible with out burning the house down?
Looking forward to your responses!
