nwsolar
- Aug 5, 2022
- 20
Good day! I am sizing my PV wire for my small system. I am using 6 ea 400 watt panels in series that give me 222 open volts. The short circuit amps are 13.97. I live in the NW and rarely see temps above 80 degrees and will be running the wire in conduit under the ground. My total run is 300 ft. Can I use 10g or should I use 8? These panels will trickle feed my battery generator @00 amp 48v) that is used approximately once a week to run my well. My panel is a 10,000kw split phase and I will be turning it off during the winter months when not in use to prevent it from consuming all the power in standby. So can I get away with 10 gauhge or should I spent the extra money for 8?
