Ok new to solar, but I do know about a little about electricity, generators, inverters and batteries.
Ok here are my thoughts and plans. Need to know if I am on the right track or is my thinking way off.
I am in the process of building a small 1800 sq ft home with a barn. barn and home will be separated by about 100 ft. I ordered 3 EG4 inverters with 6 EG4 life power batteries and 40 475 watt bi-facial panels. My plan is to have all equipment in the barn. I want to have 2 strings of 8 panels for 2 of the EG4 to have 240 v. This I want to feed a sub panel in the house and run all loads except the A/C. A/C heater, Water heater, dryer and stove will run on gas. The 2 EG4 will use 5 batteries. I also want a mini split in the master bedroom in an off grid situation.
The third EG4 will be fed by the last 8 panels and use 1 battery. With this single EG4 will run some lights in the barn and a 120v AC unit to keep a 15‘ x 20‘ storage room cool inside the barn.
I want to have transfer switch for the sub-panels to be able to switch to and from grid. Grid will also feed the inverters if needed in the evening if needed.
I want to have the ability to go off grid if needed but use solar as much as possible.
Is my thinking logical or am I way off?
thanks in advance,
oscar
thanks in advance,
oscar
