Not Aerosmith
- Sep 8, 2022
- 389
Thanks for sharing. I had assumed that if the Sol-Ark fail that it would default to bypass, but now I'm feel more confident in this assumption. I intend to connect my existing solar panels to the Sol-Ark inverter with a selector switch or MC4 connectors at my existing GT inverters. If Sol-Ark should fail or need repairs, I want to be able to switch back to my existing GT inverters. If I decide to add new panels, I can redirect the existing solar panels back to the existing GT inverter or inverters, and connect the new solar panels to the Sol-Ark.The main power from grid is fed directly into the solark, and then the entire home load of 200A is on the load output. I would expect to see power based on the CT's installed , but as of now the sol-ark is just passing the power through, and not reporting any power information.
As you have demonstrated the Sol-Ark needs either solar or batteries to operate. My intent is to buy a Sol-Ark 15 and hopefully that is all I need to change a (3) 5 KW Fronius GT system to a hybrid system. It would permit me in the future to add an additional 15 KW of solar panels and batteries.
I don't believe that connecting (3) 5 KW inverters not UL 1741SA to a single generator connection is the best way for Sol-Ark to modulate production during a power outage and match consumption especially without batteries. I believe that Sol-Ark needs and can best modulate production with consumption using solar panels connected through the (3) MPPTs versus one generator connection. The generator connection is multi-purpose for generator, inverters, dump load, well pump, etc. I prefer to save the generator connection for something else and not connect my existing inverters to it.
