It's funny- I am actually looking at getting an EV myself (despite being both totally offgrid here and in a very rural area) it makes good financial sense and even the cheaper end of the market has more than adequate range (especially when coupled with our extensive public charger system here- even my little country town (1500 people) now has a public charger, and there are 15 within an hours drive...Funny you say that, to your point ... I've said it before I will say it again, it's all about DEMAND. I think part of this, and a big consideration if you're going off-grid, is how far we get pushed into electric vehicles. Compared to a HWH or Dryer an EV is an order of magnitude different. In particular if you want to run an EV and you are 'off-grid' it is likely you will be traveling a good distance when you do use it. At a generous 4.0mi.KWH driving back and forth to town 30 miles each way, it's going to eat 15KWH (a bit more likely). I split out a 100A panel for my entire all-electric home. This is a little tight if I'm charging my EV, however 125A will pretty much cover my needs, allowing a single car to charge without a potential demand issue. I will be upgrading as time permits. I'm running standard electric appliances, with an induction range, a third inverter is in my future.
Thus conservation is surely always important, but I would not build an off-grid power plant for a 2000 sqft home, without allowing for 150A of demand from the system no matter what the various components. This get's back to the ROI discussion on gas appliances. An EV is something I definitely have a great deal more control over when it get's charged. Since I would want to build out to be able to charge an EV the additional power to run an HWH/Clothes dryer must become a demand issue not an overall power issue. The two vehicles I have in an urban environment accout for about 1/5 of my overall power needs year round, higher in the winter, much higher in spring/fall, dramatically lower in the summer.
My "starter" solar system was built for 100A of demand, because I made that determination based on the fact that I moved everything into the 100A panel one thing at a time, and monitored it with sensors. The original intent was to shuffle loads with ATS's back and forth. What a PITA / dumb idea that was, though I did write the software to do it. IMNSHO if I'm going off grid, I don't mind maintenance, but I don't really want my power plant to have to stay at the top of my mind 24x7. I want the peace of mind and confidence to know it will perform without me being involved no matter the demand or power requirement.
My 18kw of panels will be over 80kwh a day total generation (and with my 'normal usage' going between 7-10kwh a day, there is plenty of excess to run both my workshop and charge an EV)
Literally in the middle of this... 100% solar...
