Changed my inverter, using the same data logger I actually could see the power usage straight away, did not do anything.
However as the new inverter is hybrid & has batteries I needed to change type, to storage etc.
I ended up deleting the inverter off the cloud.
After that never got another reading, removed data logger & plant etc etc & re added, either on PC or Android App.
Can always see the data logger but no inverter added (I am not being stupid and missing a step? I cannot see a way to add an inverter, I assume the logger does all that. Was 8 months when I first set up & don't remember it being any other that extremely easy.
It is wired so no wifi issues. I can log in to the data logger directing using the IP.
Cannot use the wizard as oddly the firmware & www setup want to go through wifi setup?
I know it can take a good few hours to connect via the cloud but it has been all day.
I have the same setup at the same location and that is fine. Not changed it though but the server assume OK.
I do think perhaps removing & re-adding more than once might mess the cloud server setting & take a while to settle
thanks I/A
thanks I/A
