Thanks SeaGal for your prompt reply. Is it easy to programme these into the inverter setup options
Yes - simple menu option.
I had suggeseted the 6kW Solis from installer, but he says we are restricted to 5kW to grid and hence the inclusion of this 5kW inverter.
I don't know about your regulations, but in the UK (using approved equipment) we can export up to 16 = 3680W and in that case just notify the DNO afterwards. Above 3.6kW we require approval first and then will be told if the amount is allowed or, if not, what limit we can export.
If you system is similar (but using the value of 5kW, rather than 3.6kW) then it could be the case that the installer has to fill in more forms to allow you to use a 6kW inverter that has (in UK terms, G100 export limitation control). So, guessing here, it might be a bit more work for them to do that, but IMHO worth it in the long run.
How flexible are these inverters , can a 5kW limit to grid be set on the 6kW version.
Yes - on my Solises - any value from zero upwards in 100W increments. I have my S5-EH1P6K-L set to 5kW export limit.
In addition I see that the recommended charge/ discharge current limits for proposed Dyness BX51100 Battery is 50A, will result in only a max of 2.5kW been charged into battery,Have you any opinions on the Dyness range?
I have no experience with that battery as I built a DIY storage system.
However, if I am assuming you are considering just a single 5.1kWh battery, then a 50A limit would be normal, resulting in max 2.5kW charge or discharge rate. Ideally you should have at least two of those in paralled which will give you double the capacity, but more importantly, twice the charge or discharge rate. The S5-EH1P6K-L (or S5-EH1P5K-L) supports 100A max.
