Dave911
Manual mentions the following for installation:
3.1 Installation location
ASP series is only for indoor use (protection level: IP20). Before selecting the installationlocation, users should consider the following factors:
A solid wall
Installation height: flush with the line of sight
Sufficient heat dissipation space
Ambient temperature: -10°C−55°C (14°F−131°F), to ensure optimal operation
*dimention drawing of required free space around inverter*
DANGER
Do not install the inverter near highly flammable materials
Do not install the inverter in potentially explosive areas
Do not install the inverter and lead-acid battery in enclosed spaces
CAUTION
Do not install the inverter in direct sunlight
Do not install or use the inverter in damp environments
So, mounting it on 2x4s or a plywood backing is acceptable... just don't store oily rags, gasoline nor hay bailes close to it and you should be ok....lol.
Its impressive that they consider ambient temps up to 131 acceptable.
