LouiseSJPP
I'm designing an island system to run my spa. It's a panel-led design as I can absorb all the energy produced, I need a roof for my log store and the size I an make it is limited by the property constraints.
The panels I'm looking at (https://www.leroymerlin.es/producto...solar-ja-solar-405-w-full-black-90349686.html) are full-black 405 watts. I can fit an array of six. One ide of the array is against the higher wall of the house, and thus will have some shading: a little bit of sun shading on the far right side before midday, and thereafter, from the right to the left, diminishing obstruction of the blue sky. For this reason, I'm thinking to make the array three pairs of panels to minimise the impact of shading across the array.
Is this sound thinking? If so, do I put an MPPT on each pair? I've seen something called a panel optimiser, but suspect this is for AC output, whereas I'm going to battery and inverter.
I think I'll be at best 75% of the 'normal' output, given angle and skope, of the panel (https://globalsolaratlas.info/detai...&c=42.510577,-3.131104,8&pv=small,150,22,2.43) because I have a steep hillside and trees to the north, and a mountain range to the south, neither affecting direct sunlight but both impinging on blue sky. Can I safely knock down Isc of the panels for this and the non-optimal panel orientation when sizing MPPT and inverter?
