I just purchased a 2017 Tiffin Allegro Breeze 32 BR motorhome. It currently has a 1250 watt inverter to run its Whirlpool refrigerator and other outlets in the coach. The current battery system consists of two lead acid 6 volt batteries in series under the entry steps and two 6 volt lead acid batteries in series in the front of the coach. The 6 volt batteries in the front are separated and a battery sits on each side of the generator.
I am considering a 24 volt system by replacing each battery with a 12 volt lithium battery. Can the lithium batteries be separated in this same fashion? Not only is the front series separated for each other but the two series are also separated. Will the Victron Battery Balancer control any issues?
I hope to eventually have a 24 volt inverter/charger, a 12 volt to 24 volt B2B charger, and a 24 volt solar system. I realize I would need to convert back to 12 volts to power the motorhome.
Any advise would be appreciated. Thanks.
