In case it wasn't obvious from the answers you received, you didn't provide the needed information to get good answers.
The voltage of each panel isn't important to string performance/efficiency. It is important to your charge controller, but you said it was fine.
The current will be the same through the entire string, so the lowest current panel will drag down the other two. The voltage just adds up with each additional panel in series, so no effect on how the other panels are performing.
Asking what order to put them in series reinforces the theory that your learning. You should be open to answering questions so you can better understand how solar works.
