Most of the shelf BMS's have passive balancing which dissipates an overcharged cell to balance the pack. I've added an active balancing board that moves power from overcharged cells to undercharges cell(s). In theory, when a pack has only one cell with a lower voltage, the passive or dissiapative BMS blanancer will start dissiapting 3 higher voltage cells while the active balancer takes power from higher cells and transferes it to the one lower voltage cell. The end result, in theory, is they meet in the middle with the least power turning into heat. This also depends on the voltage difference and how far into the knee of the charge you are.. > 3.3v to 3.65 (max). I've also done testing with manual balancing and discovered the cells don't accept much current when the start voltage is 3.450 and target is 3.5v.. it charges at a whopping 450ma.
