kissa2
- Dec 23, 2020
- 2
I have a JK bms with active balancing and today I experienced for the first time low cell voltage protection kicking in. Checking the battery status I noticed one cell was significantly lower than other three cells. My shunt said there should have been over 11% of battery capacity left in m 304ah lifepo4 battery bank. (The lowest cell voltage was 2.7V and other three were above 3.06V)
I realised I could still pull some power of the battery in its current state after activating cell balancing to raise the lowest cell voltage. I'm using someone's recommended settings for my bms from this forum and cell balancing is set to start at 3.3V. I'm wondering why is it recommended (or is it?) to use cell balancing only at higher voltages. Wouldn't it be useful also to enable cell balancing at lower voltages or all the time to pull more power out of my battery bank?
