I might be mistaken but I thought RVs were grounded to chassis?As I wire a question pops up...the ac neutral busbar in my RV is isolated (no ground bond) so this is a sub panel, correct? That means shore power is the main service.
Thnx Donlumber for the info! ...yes chassis grounded. I didn’t understand why AC neutral wasn’t grounded at the RV. Then I learned my RV panel is a sub panel, meaning neutral is bonded either at the inverter or shore power source.I might be mistaken but I thought RVs were grounded to chassis?
That is only 3.32 V per cell which is before the steep part of the curve. That is more like the resting voltage. But as you say they are bottom balanced so if you charge to that voltage you should have no issues. Are you going to use a BMS?The target voltage is 26.60V
