The universe is telling you you have enough alreadyD*mn!
I thought I had a line on 2x Sunny Islands and 2x Midnight Classics for cheap.
Looking back at my records that brand new picked up at the manufacturer forklift battery appears to have eaten over half my power from day one.LiFePO4 became highly competitive over the past few years.
Several years ago, lead-acid price was more competitive.
For capacity to handle 3 days without sun, the difference in lifespan may be nil (vs. a system cycled 100% every night.)
Murdered forklift batteries negating that. LiFePO4 can be murdered too, but BMS supposed to prevent that. If FLA was invented today it might get similar protection, but dates from where that was a human job.
We're pretty efficient, I designed this place knowing id likely remain off the grid, plus our climate is very mild. That 2200# forklift battery, who knows how many gallons (barrels) of battery acid I had to heat and keep warm. It was in the back of my mind, yes but in more of an anecdotal way, now looking empirically it's simply staggering. My original calculations weren't off, I just didn't adjust for 50% battery efficiencyI understood FLA consumes 1/3 of the power delivered, you get back 2/3. Put another way, what it consumes is 1/2 of what you get back from it.
Only from reading, I've never lived with FLA beyond small size.
I do use AGM, and I'm not logging its performance. Way over-paneled and grid-backup so most of their life spent basking in Float.
You probably have efficient off-grid house. I simply installed excess PV, back when I thought rebates made it a good deal. Was break-even with utility at best over 17 years. Today, PV + LiFePO4 is much cheaper (but if using lead-acid, lower cycle life may make cost same as grid.)
Only takes energy to heat, not to keep warm. As you discovered when you insulated it. Maybe needed insulated enclosure and thermostatic vent.
Apparently insulation works for LiFePO4, just need a bit of electric heat, so even simpler.
I would consider if starting from scratch, but maybe only top name BMS like REC would be reliable? Even then, issues configuring.
I have strings of AGM for all.
Victory! The (2)BMS, the SI6048, and the Whizbang Jr are showing SOC within 3% of one anotherD*mn!
Of course, I'll probably have to start over with this every time I add another 200 amp hours of battery, which should be two more times this summerVictory! The (2)BMS, the SI6048, and the Whizbang Jr are showing SOC within 3% of one another
